Hi, does anyone know of a rwd gearbox that will go on the fiat engine without too much hassle?
I am putting a 1.2 8v fire engine in my reliant kitten, the original plan was to use the standard gearbox (like the mc750 guys) but im starting to
worry about longevity and seen as i intend to use the car regularly a 5th gear can't hurt.
Cheers for any advice
[Edited on 12/8/17 by accutherm]
There's a polish kit car in development that uses the fire engine as a transverse mid engine. It uses the standard 5spd gearbox as you find in seicentos and Punto's. I've had a Punto in the family from new and it's on 140k, and 2nd synchro is going but apart from that it's fine so I wouldn't worry too much about longevity unless you're massively tuning for power.
Ah sorry i meant the standard reliant gearbox. They have been known to be unreliable with the standard engine and the 1.2 fiat has 50% more hp.
I am pretty sure the fiat 124 / lada riva box will fit straight on, dont think they are on every street corner tho.
FIRE engines are not the same bellhousing pattern as either the Lampredi dohc or sohc engine families. I know of no north-south applications of the FIRE engines. I would say you need an adapter plate and a gearbox of your choice.
I can get a adapter plate made, id need one for the reliant gearbox anyway. My problem is more with the clutch assembly. With the reliant gearbox i
know what bits id need but for another gearbox im completely clueless .
Im not going to be pushing any more then 80hp or so so the gearbox doesn't exactly have to be sturdy.
You need to look at the regs for the 750 Formula as this is the engine they use and i think it specifies the gearbox you can use.
It might be worth looking at the Liege rally cars - I think they swap out the Reliant box for a Suzuki Jimny 5 speed box? Doesn't help with your
query directly as you'll still need an adaptor plate but may be the smallest/lightest/cheapest rwd box that will take the extra power and you
know it'll fit in the chassis?
[Edited on 12/8/17 by scimjim]
Cheers ill look into the jimny box. Id never considered them
