Hello
I'm having trouble with starting my car, which I've had for 7 years but, now won't start
The engine turns over, and after 10 secs of cranking, starts to run for about 5 seconds then cuts out.
It's on Jenvey's with OMEX 600
Here's what is working:
Compression - good pressure on compression test and nothing on the leakage test
Spark plugs spark, tested with inline light tester, and by taking the plug out to see the spark
Injectors are opening, verified by fuel in cylinder and by looking down all 4 Jenveys to see good cone shaped spray
That's all they need right? Compression, fuel and spark
Additional diagnostic steps taken:
Fuel pressure is strong and remains constant when cranking and running (when it runs for a few seconds)
Timing, today belt removed and set back up using timing kit
Crank sensor replaced, just to see if that helps - it didn't
Coil pack replaced, just to see if that helps - it didn't
Omex connected to computer and stays live, doesn't switch off
Water and air temperature sensors are accurate
Battery voltage constant, thanks to external power / jump starter
Additional info - it's never had a camshaft sensor and it's had the VVT removed from the inlet camshaft
[Edited on 27/8/17 by barraw]
Does it run for 5seconds on tickover or are you trying to rev it
just trying to run on tickover. It normally fires on first turn and runs on tickover cold, at 1,000 rpm
As soon as a try to rev it, it dies. Tried 5% throttle, won't even start if any throttle open
Have you checked TPS settings
On mine I have to keep it at about 1500 rpm when I start it cos it just cuts out on tickover
I can't even get it up to 1,500 rpm - just dies if any throttle is applied
Before I had these problems, it would sit at 700RPM all day
I mean can you recalibrate you're TPS
the TPS calibration is spot on, 0 with no throttle to 100 at WOT
Could be coil breaking down timing out fuel table out ignition timing air leak lots of things to check unfortunately
Crank sensor breaking down
[Edited on 28/8/17 by chris]
If ticking over and dying when throttle applied then I would say the problem sounds like tps. Remember it is this that controls ignition spark timing
fuel etc. Through your ecu. I have no experience with yours but my throttle positions are 20 closed and 87 fully open. Mines is emerald. Yours sounds
to perfect to me.
[Edited on 28/8/17 by Hornet]
Hi
the TPS raw values are 18 to 229, which is calibrated as 0 to 100
Is there any way in OMEX 600 to get a tooth control table, to validate the number of teeth between the missing teeth?
I'm only getting 3 timing errors in 10 full revolutions in the engine (at 200rpm / starter motor speed)
Could anyone share their ST170 OMEX 600 config please?
Is there anyone in the Retford, Notts area who could help? Happy to pay to get it fixed
