Ive just swapped the thermostat on my silvertop to a 92degree item as I was experiencing the usual over cooling from the water rail.
What temperature should I be setting the fan to start with this stat. I guess around 100?
[Edited on 10/9/17 by AntonUK]
Mine comes on at 103 degrees, off at 96. mines a Blacktop
Ford setup istr is slow speed on at 105c
Mines on at 96 of at 90
On at 90 off at 85
