Exhaust Gasket Temperature Range
Ivan - 21/2/18 at 08:56 AM
I need to get a flange gasket cut to fit between exhaust sidepipe and exhaust manifold. What temperature gasket material should I request - it will be about 18" from the head. The suppliers have suggested 450 deg C material but I just want to check. My gut feel says closer to 650 deg but that will increase the cost.
40inches - 21/2/18 at 09:04 AM
At 18" from the head 450 degrees will be fine. Mine are around 12" and I used ordinary household silicon sealer as a seal. 1000 miles on and it's still sealing
