Good news! Managed to get my car a 12 month ticket with no advisories after 5 years off the road (: however driving it to the station I got some
hesitation under certain loads.
Wondering if anyone knows the FPR value and injector cc (brown) for a 2.0 silvertop. I've found some values online but they are wildly different
to my Emerald base map which is currently set at 2.7 bar and 200cc. This is different to the online sources so wanted to check what other people have
found the true values to be?
I did try the search function, perhaps not well enough
TIA
Are you running a Ford inlet manifold ?
If so, check the injector seals from the rail to the manifold.
[Edited on 10/8/20 by big_wasa]
Correct, it's got the HO 130 inlet manifold with standard injectors.
Will add that to the list of things to check. Just want to make sure it's not the map parameters first. It drives worse the second time you start
it. I assume this is down to the ECU (K6) 'clean up' after first switch off.
