Hi All
Need aiming in the right direction..
Got a dry sump system that uses a side mounted oil pump - VW ABF 16v engine - and the adapter plate that goes between Pump and the block is a unicorn!
(apparently a batch of circa 10 were made, in Germany, back in the 90's, of which mine is one, they are unavailable)
The one I have I would like replicating a few times, hence need to find somebody who can do it, as it's quite a complicated shape I think a 3D
scan and then it CNC'd from a block of Ally would be the solution.
Anybody any ideas who supplies such a service?
Or - alternative ideas to the above!
Might be worth getting in touch with RetroPower as they do a lot of 3D scanning (watch their YouTube channel) and I'm sure can machine things from those scans.
Thanks, will do
I have a couple of 3D scanners and can scan, but it would be on a hobby basis, I have a full time job doing other stuff 🤣. I dare say it
might be better to measure and reverse rather than scan unless you,think there is critical surface geometry that needs to be extracted? Happy to give
it a go free of charge if you donate a beer when you make your millions.
[Edited on 8/10/2024 by coyoteboy]
Hi Jim
I have a good friend that has the kit and know-how to carry out that sort of work.
PM me you would like his contact details?
Gary
Check out the making for Motorsport guy on YouTube.
https://youtu.be/imGrla3b3Mo?si=tuhsXJUGA9u7Ed2n
I don't think it's as easy as scanning it in, there's still quite a bit of post tweaking needed.
Please let us know how you get on.
