I'm reasonably certain that all of the 4 cylinder K engines are physically identical externally. So it wouldn't be difficult to exchange the
1.4in the GTM for a 1.8
The question is, what cars use(d) the 1.8 -apart from the MGF and Elise.
Any ideas ?
Did they ever make a 1.8 Rover 25 ?
There is a 1.8 75 with a K series. It's also in the 1.8 Freelander. But there have been very expensive reliability problems with them. See here
From about 1995 all K series (K8 and K16) from1.1 to 1.8 used the same cylinder block but with different wet liners.
The bigest difference between the installation is the gearbox --- up to 1.4 litre a Pug gearbox ws used, the 1.6 used a much stronger Pug gearbox
while the 1.8 used Rover own PG2 gearbox. The 1.8 was used in the 200, 400, 25, 45,75 various MGs. The engine management system and injection
system are significantly different on later models.
With K series the smaller engines are much sweeter running personally I would preffer the 1.4 or 1.6 to the long stroke 1.8.
[Edited on 17/2/05 by britishtrident]
Id agree with british trident, the smaller capacity engines feel to have the edge to me.
British Trident,
From my experience the 1.4 seems to have the most variation in build states, i believe that the earlier ones, as you said, were a different block and
some have strayed in to some fairly new cars, and there is also a couple of different heads which are used on the 1400.
The new versus old profile cams combined with the new versus old profile heads makes quite a difference.
I think for a seven on a budget i would alsays go for the 1600 because its got the extra torque you want to take tolerate better the "unsporting
gear ratios" normally avaiable, and its a good power, economy, weight trade off. 120bhp of silky smoothe k power goes along way in a light car.
I guess the reason for considering a larger engine is because the GTM is relatively heavy compared to a se7en at over 700kg. I know, I know -
that's flyweight compared to most series production cars.
I'll wait until I've given it a chance before I say any more.
John F
