Split cam
darren(SA) - 5/11/02 at 09:40 PM
Hi guys,
I'm sure you guys have heard of a split cam,(although haven't seen anybody mention 1) anyway, In SA, this is a fairly new idea(always behind you guys). I got myself a 276/268 (276 on exhaust I think, 268 inlet) for my golf and was Impressed by the gain in topend with minimal loss in bottom end(comparing to the normal 276).
Now, getting to the point, I have a 288 cam sitting in my fully modded 1600 crossflow (yet to be started->biting nails)
and was just wandering If anybody has ever put in a split cam (say 288/276) in there crossflow?
JohnFol - 6/11/02 at 09:15 AM
I've not heard the phrase before. What is a split cam?
MK9R - 6/11/02 at 11:21 AM
Is that the type of camera used to make porn films??
Mark Benson - 6/11/02 at 02:00 PM
The only thing I can think you mean is a system like Honda's vtec system?
2 Cam profiles on the same shaft, the shaft 'switches' at a pre-determined engine speed allowing greater lift from the valves.
Gives the benefit of high-lift cams but without the loss in low-end grunt.
How that would translate to a crossflow I have no idea.
Big Stu - 6/11/02 at 03:03 PM
I read it that the cam profile is different for the exhaust than the intake? or have I got the wrong end of the shaft?
James - 6/11/02 at 04:28 PM
That's the way I understood what he was saying aswell.
James
darren(SA) - 6/11/02 at 07:54 PM
thats correct. For mine 276/268 the 276 on the exhaust 268 on the inlet.I think it decreases the overlap? anyway, gives you same topend as 276 and retains stronger bottom end.
Most cams for the 8v's are cut with the same duration on the intakes as the exhausts. So a 276 will have both the intakes and exhausts at 276 deg duration. A split cam will have different exhaust durations than intake duration and what that means is that you can say have a 276 exhaust and 268 intake which gives a very nice 'inbetween' compromise. They tend to idle a lot less erratic - drop less bottom end and still have a bit of oomph up in the rev range.
from the GTi website of SA
darren
