Gear Stick Out of Reach!
I have bought a Locost 90% complete and am currently converting it in to a Race car.
The thing is the gear stick is half way up the tunnel and it is hard to reach. I haven’t yet put in a proper seat, but using the bits of foam (that
came with it) as a seat meant I could reach the gear stick but I couldn’t move my legs!
See below:
Gear Stick
I can take some more shots without the internal panels on (they weren’t the best).
Is this normal for a Locost? I am not particularly tall at 182cms (6ft) and I am wondering if the original builder didn’t shorten the prop enough or
mounted the engine too far forward, hence the stick is out of reach.
Is there a easy way of compensating for it (like a z shaped gear stick) or some fancy / will go wrong gear link set-up?
Any help appreciated.
Regards,
Richard.
westfield do a lever extension - for £85!!!
Westfield link
and there is also someone on this site who detailed how to fabricate your own - not sure of the link though.
someone will be able to dig it out im sure - ive searched but cant see it
all the best,
Tom
There are a number of different ways of moving the lever back. Extending and bending it is probably the easiest but gives a long gearlever travel.
There are some photos in my archive showing how I did it. Others have taken similar but different approaches.
Hope this helps
Another site allong similare lines to DavidM
http://www.locostcarclub.co.uk/
Clikck on the help button at the top and theres info on a lot of locost issues.
[Edited on 13/4/05 by clbarclay]
The best way to do this I would have thought would be to fabricate your own remote.
If you know how to use a ruler and can cut steal it shouldn't be too hard.
Normally the gear lever is just given a dog leg, no problem, the throw of the gear lever can be adjusted to give a shorter throw by removing the
gearlever and ball and adjusting the postion of the lever in the nylon ball with a small mallet.
I suspect yor lever is so far forward that you have a basic Escort 4 speed box, the Cortina and Sierra gearboxes are longer bring the lever a bit
closer.
The best mounting postion for the engines is as far back as possible -- normally this means the rear face of the bellhousing is almost in line with
the footwell bulkhead.
Westfield type 9 extension on the back of billy quaife.
I can take more detailed pics if required.
G
Thanks for all the help.
Heres a pic of the engine location (I know its a bit of a mess):
Engine Location Close Up
The bell housing is a country mile away from the bulkhead!
I will have a go at a z style stick extension otherwise i'll have a crack at the linkage setup.
Thanks for all the info & the links, very useful.
Regards,
Richard.
As a rough guide with a 4 speed & xflow the top of the gearbox cover should only be slightly protruding from beneath thebulkhead top panel iirc.
Looks like the engine could move back a fair bit.
Could you tell me how much further back that puts the gearstick? I hadn't heard of these before and it would be perfect
http://www.locostbuilders.co.uk/viewthread.php?thanks_for_the_reply
I've been thinking of an extension for the gear lever. Mine is the same setup as rthurbin.
Here are some scribblings of a madman
I was thinking of using some bar and a balljoint for the 'second' stick.
Hope they are of some use (and the rest of you be nice
Tiger do a version of the above method - although the extension bar is above the tunnel cover.
