Hi all would a bike sprocket be any good as a trigger wheel?
Adrian
Ive seen pics of bike sprockets used as trigger wheels, but think the sensor position would be quite critical due to the narrowness of the teeth.
I used a trigger wheel i removed from a Sierra and fitted it to a homemade alloy pulley for my crossflow.
Paul
Adrian
Not sure,
The tips of the teeth are a much smaller area than on our proper trigger wheel.
Although if you ground the tips off that would be rectified, and Create the missing tooth of cause I don't see why not.
I'm presuming you've already got the bike sprocket, otherwise u'd be better off getting a proper trigger wheel off a 1.8 CVH
Hi guys
I havn't bought one yet, because i was a bit worried the teeth might be to pointed
I didn't no sierra's had them? are they easy to get off?
Adrian
The 1.8 CVH Sierra Has the Trigger wheel on its crankshaft pulley, on the inside edge I think (up against the engine block)
Which can allegedly be prized/forced/pulled off the pulley.
Ours cost us a Fiver, probably cheeper than the sprocket?
Try looking for info on Megajolt Systems and peoples builds/installs for more info.
Heres a photo of one on my alloy pulley.
Hi guys
Adrian
yopu can buy them new from ford for about £12. Better option than making one.
Do a search on here - the part number is on a thread somewhere.
I used a Sierra one on the front of my Zetec:
