I've been offered a 205 block Pinto engine that's been sitting in my father-in-law's factory for a few years. After a bit of
investigation I managed to work out that it's a low compression jobbie originally fitted to a P100 pickup .
A nice chap at Vulcan told me that it's just a case of fitting the proper pistons and con rods to get the thing up to standard spec (or Cologne
V6 ones if boring out to 2.1).
I don't particularly like the idea of parting with the kind of cash Vulcan look for, and I wouldn't mind a crack at doing some of the recon
work myself.
So, where do I start?
Ta,
nobby.
Just phone colibriman and save your self the grief.......
Where are you in the country nobby?
I might be able to recommend someone if you are in the north east.
Mark
likewise I can recomend a good machine shop down south who helped with my rebuild.
For me the choice was dictated by the cost/simplicity of installation.
If you use a Zetec/Vx/Duratec/4AGE, you probably won't need to rebuild it, but you will need to sort out the fuelling and ignition.
I used the Pinto, because the donor Sierra came with a ready to use set-up and gearbox, which made the rebuild seem worthwhile (for me).
HTH
Nick
Mark
Originally posted by nick205
For me the choice was dictated by the cost/simplicity of installation...
...I used the Pinto, because the donor Sierra came with a ready to use set-up and gearbox, which made the rebuild seem worthwhile (for me).
HTH
Nick
I know where you are coming from, as I love to do things the awkward way against all advice.......but...........get one s/h that somebody else has already rebuilt. The bits to do a proper rebuild will cost twice what the rebuilt engine would sell for secondhand!
