Does anyone know which thread the Zetec has for the oil pressure sender?
Thanks,
Marcel
Both holes are 1/4 bsp (1/4nptf)
Are you sure about that? It looks bigger. (haven't been able to extract it out of the block, but I need to know which T-piece I need to order to
plug in the warning switch as well as a VDO pressure sender)
{edit: okay, I just found on Think Automotive that you're right! Thanks!}
Marcel
[Edited on 22/7/05 by Mave]
Originally posted by Mave
Are you sure about that? It looks bigger. (haven't been able to extract it out of the block, but I need to know which T-piece I need to order to plug in the warning switch as well as a VDO pressure sender)
Marcel
