Petrol pong
David Jenkins - 1/8/05 at 01:25 PM
I'm getting a very strong smell of petrol when the engine's stopped after I've been out for a run in my car. Sniffing around, it seems to be coming from the top of carb, through the air filter (I've checked for leaks elsewhere).
It's a 32/36 DGAV on a 1660cc x-flow, using the engine's mechanical fuel pump (so hopefully not over-pressure). My first thought is that it's either a dirty float valve, or it's gone out of adjustment and the level's too high.
Can anyone say whether my guesses are likely candidates, and is there anything else I can look at when I've got the lid off the carb?
cheers,
omega 24 v6 - 1/8/05 at 04:16 PM
Have seen the floats breaking away from the soldered joints on these carbs which usually just floods the engine. Could be a build up of heat in the engine bay which in turn is boiling off the petrol in the float chamber ( can you hear it boiling when you stop the engine it should be audible).
That's my tuppence worth for now someone else will be along soon.
JoelP - 1/8/05 at 04:50 PM
mine stinks of fuel too, 1640 with twin webers. I had assumed it was a natural thing, probably wrong though... All adds to the buzz
SeaBass - 1/8/05 at 06:02 PM
I'm using the same carb - but there were many versions. On my particular version there is a small but significant hole into the top of the float chamber if you look carefully. This is obviously meant to be there to release pressure when fuel enters. I think this couple to the fact the engine warms the carb mean that warm fuel evaporates through this small hole when the car has been out for a run...
