Hi Guys,
I am selling this engine as a 2 litre Pinto (came with my rolling chassis, told it was a 2 litre Pinto, but I am using a 1700 XFlow)
When I look at my 1.8 litre pinto (which I got from my donor Sierra), it looks quite different.
Can anyone tell me what it is?
Mark (Sorry for the stoopid question)
[Edited on 5/1/03 by Mark H]
Thats a Pinto mate.
Has your Sierra got a silver rocker cover, with the dizzy coming out of the top of the cam cover? That'll be a CVH......
Definate Pinto, could be either 1.8 or 2.0 with that colour cam box/timing cover/carb combination. only certain way of knowing is to strip & measure
bores, OR to make a note of engine No's and make a nuisance of your self at your friendly neibourhood Ford dealer/engine builder/policeman(dvla but
they aren't allowed to do that anymore).
You could use carb No's but that will only tell you about the carb.
It should say on the block what the capacity is (cast into it)
Late pinto's all used the common 2.0 block with the same block height for 1.6/1.8/2.0. the ONLY difference (even the cranks are the same) was in the
cylinderbore so the only way to tell is to strip & measure or to refer engine No's through dealer/manufacturer/dvla.
Enjoy
Thanks as always for your speedy replies.
It is as Stu16v describes - must be a CVH!
Jolly Green - Is that picture of you in your locost bucket seat. If so, have you got pedal extensions?
Mark
Two pedals - Stop And Go. as you can see I have a five point harness but I am vertically chalenged so I get my kids to do the work by proxy. My sons
on stop cos my duaghter never does stop. She rattles on worse than a diesel on ether!
Enjoy.
Actually its only part me, some of it was my son 11 years ago.
[Edited on 6/1/03 by jollygreengiant]
bloody hell u must be a geriatric if ur son had a beard like that 11 yrs ago
