Zetec Flywheels?
Surrey Dave - 25/10/05 at 07:35 AM
I have a 2.0 Zetec and I would like fit an 1800 zetec flywheel, will it work on the 2.0 manual crank position sensor, or are the 2.0 and 1.8 CPS different?
I could fit my 1800CVH flywheel but I'd rather not..............any other good lightweight flywheel options?
lsdweb - 25/10/05 at 08:22 AM
Hi Dave
AFAIK the flywheels will have the same pickup etc.
I used the CVH flywheel as it can be lightened much more than the Zetec. I have the crank sensor mounted on the front pulley instead - very easy to setup with the Emerald system.
There are some photos in my archive.
Regards
Wyn
Mix - 25/10/05 at 08:42 AM
Yes the flywheels use the same sensor.
Mick
Surrey Dave - 25/10/05 at 08:55 AM
Wyn,
Do you know the weight of your CVH flywheel when lightened?
lsdweb - 25/10/05 at 09:14 AM
Sorry Dave
I didn't weigh and I'm not taking it out now!
The guy who machined it assures me it is lighter than you can get the standard Zetec. I could probably ask him as he was building another engine with the same flywheel- that was a year ago though!
Regards
Wyn
