Pinto piston fit - opinions please
ed_crouch - 7/11/05 at 06:11 PM
Chaps/chapesses,
Just honed out the bores of my Pinto lump (just a gentle hone to break the glaze).
I trial fitted the pistons in afterwards, without rings, and found that they are not exactly a dead tight fit in the bores. There is a small fraction of a millimeter gap: just enough that you can see them move around.
Is this normal??
The pistons still have the machining marks around them, and the bores still had cross hatching on, so I cant beleive that its worn out. Confused...
Any opnions would be appreciated.
Ed.
Jon Ison - 7/11/05 at 06:22 PM
yup sounds ok too me, its the rings that do the contact not the pistons, all they do really is carry the rings up and down the bore, oh and fill the hole in the middle.
ed_crouch - 7/11/05 at 06:25 PM
Thanks, Jon.
Ed.
mookaloid - 7/11/05 at 06:28 PM
Agree totally with Jon. Also there needs to be a bit of play as the pistons will expand when hot and take up some of the slack.
Mark
romer - 7/11/05 at 07:38 PM
If you want to be absolutely sure about bore wear, you should pop one of the piston rings into the bore (without the piston) maybe 1/4 to 1/2 an inch down so that it sits in the area that the rings would normally slide on when running. Make sure the ring is sitting square in the bore ie parrallel with the top block surface and there will be a gap where both of the ring ends don't quite touch to complete the full circle. You then need to measure this gap using feeler gauges and check it against what the manual says is the correct gap. Too big a gap and the bore is worn
Make sure though that you're using new rings, because if the rings are old (and worn) then that will also make the gap wider.
Hope that helps
Romer
