banjo bits!!??
joolsmi16 - 19/11/05 at 09:57 PM
Hi all, Iam trying to figure out what I need to extend the standard 3/16 brake pipe from the master cylinder to the standard banjo fittings on the blackbird motor??
The manual states that a 10*22 oil bolt is used to secure and I would like to know what brake union I can used so that I can thread this oil bolt (single banjo bolt) through the banjo into the brake union??
The other thing is I need to extend the oil cooler hose and it all has Honda fitting I can cut the flexi oil hose but what fittings can I get to attach the extension and re-attch the standard oil cooler??
Jools
