XE big end bearings
NS Dev - 22/11/05 at 11:29 AM
Can anybody get me a good price on AE "sputter" big end bearings for an XE engine (early crank type) on std shell sizes?
I can get them though my local supplier but cheap they are not!!!
The Lead-Copper ones are MUCH cheaper but only available in 8 valve width which is a few thou narrower and actually no stronger than std white-metal 16v bearings apparently.
Ben_Copeland - 22/11/05 at 11:35 AM
Have you tried AutoVaux? I can get trade price through Vauxhall, but they are bound to be more expensive !!
www.autovaux.co.uk
NS Dev - 22/11/05 at 11:53 AM
I'm after uprated ones though, not std material bearings.
Autovaux are certainly good, have had a few things from them in the past, but I need the sputter bearings really, not keen on the std ones after having some "incidents" on the rally car in the past!
Ben_Copeland - 22/11/05 at 04:53 PM
Ah ok... SBD ? Sure they'll be as expensive. there are a few others but sure you know them all !
Stu16v - 22/11/05 at 09:37 PM
IIRC the sputter bearings are also 1mm narrower than XE, having been originally destined for the lo-blo diesel...
The other option are the genuine GM bearings. Unless they have recently come down in price, are bloody expensive though...
