K series identification
Hammerhead - 29/11/05 at 10:50 AM
Hi all,
I have a K series engine from a 97 Lotus elise. There is some confusion on the capacity, the previous owner thinks its a 1.6, I reckon its a 1.8 as I dont think that elises were ever fitted with the 1.6........................are there any identifiers on the engine that will tell me for sure the capacity??
Cheers.
flak monkey - 29/11/05 at 11:06 AM
The elise was only ever fitted with the 1.8 engine.
The block on all of the K series engines are the same, but they do have different numbers stamped on them.
There were also 2 or 3 different heads and crankshafts fitted to the K series range....
Makes it all a little complicated. However if it was an elise engine then it will be a 1.8
Hammerhead - 29/11/05 at 11:16 AM
Thanks for that David - the previous owner had the engine removed before delivery from the factory and had the VHPD engine fitted instead.
At least now I can start getting the correct ecu's etc.
Cheers.
flak monkey - 29/11/05 at 11:17 AM
You have U2U
Hammerhead - 29/11/05 at 12:56 PM
right back atya!!
Humbug - 29/11/05 at 08:51 PM
If you check the engine number, the first 2 digits indicate capacity. My 1.4 starts 14KMM...
