How much oil in type 9 ?
donut - 1/12/05 at 10:39 AM
Anyone know the correct ammount of oil i need to put in my type 9 gearbox? Done a search but nowt came up.
ta
andyd - 1/12/05 at 10:51 AM
Make sure it's roughly level and fill until it runs out of the drain hole. The correct level is upto the bottom of the drain hole I believe. Well that's the advice I've always used. Someone else may have better info.
donut - 1/12/05 at 10:57 AM
Same as the diff then! Cheers i'll go put some in.
02GF74 - 1/12/05 at 11:02 AM
that's sierra right? Normally the quantities are in the haynes manual - I happend to have ended up with 2 - make me an offer and it is yours - postage is about £3.
Mark Allanson - 1/12/05 at 11:22 AM
Haynes data manuals seem to vary depending on the engine (!?!), but are between 1.2 and 1.5 litres
SixedUp - 1/12/05 at 08:05 PM
Correct answer is to fill until it reaches the bottom of the filler hole. Cant remember how much I used when I last did it though ... I seem to remember a touch over a litre, but I could be wrong.
Richard
donut - 1/12/05 at 08:35 PM
Well it can't be any more than a litre cos that's all i got
NS Dev - 1/12/05 at 11:27 PM
It's 1.9 litres I'm afraid!
It's also supposed to be filled to a tad lower than the level plug for some daft reason but best to just fill to the plug level, a touch more will help keep 5th gear in good nick and at worst will just cause the 'box to breathe a touch more oil out.
