The part built car I've bought has an electrical switch from the clutch master cylinder - any ideas why this would be? Original engine would have been a Duratec
Fluid level maybe, or a switch so the car only starts with the clutch down?
Cruise control?
Standard ecu used?
Fluid Low level?
[Edited on 9/12/05 by stevebubs]
Somebody used a brake master cylinder for the clutch?
Caber
Don't worry about it, I'll run it in series with the brake fluid level, that way you get a warning if either level goes down !!
Jason
[Edited on 9/12/05 by Deckman001]
Hi Jasper
Is it a level switch or a pressure switch?
If pressure it may have been to connect to the ecu for full throttle gearchanges
Adrian
More of a discription would be handy, but if it's got a float attached it has got to be a fluid level warning.
Cheers for the reply chaps - just gonna ditch it completely......
