Which would be better on a 2.0 pinto with decent cam Zx9R or GSXR 750 (38mm) carbs?
[Edited on 14/12/05 by donut]
I would have said the ZX9r carbs myself for the 2L. Although obviously will depend what setup you are using eg. high-lift cams etc.....Hope that helps Oli.
Not sure what cam yet, probably one of those torquey ones.
what bore size are the zx9 carbs?
do they mount at more of an angle?
38mm i think...or rather i was told!!
I think they are all more or less the same Dave.
My ZX7r carbs are 38mm so I would have imagined that the '9' would be bigger (40 maybe?) The 7's mount at a 28 degrees of vertical angle, I'm not sure how this compares to the others but I should have thought they are all pretty much the same....My set of ZX carbs do look absolutelty....well....bling! would be one word to describe them! To be honest either of them would probably suite your application and they'll all perform much the same aswell! I'd go for which ever one is easiest to get your hands on for fewer notes! If you go the ZX9 route let me know I maybe able to help you out with a manifold. Oli.
Hi Donut i am just in the middle of fitting zx9r carbs to a pinto 2l . zx9r carbs are 40mm . i rang bogg brothers last night and they say there good
carbs to use if i can help you let me now Jacko
ps they said use a fr32-33 kent cam give them a ring on 01944 738234 very helpful people
[Edited on 14/12/05 by jacko]
Thanks guy's
Yeah Bogg Bros are the biz, they did me some inlets for a Zetec. Also i'm the guy who designed their website so i should get a good deal!!
Thanks for the info.
Do you want a set of 40mm R1 carbs
Not for £75 mate!!
Make me a decent offer
erm....... ZX9R carbs go for about £40 so how about.............(U2Usent) -
I'm now the proud owner of some very nice R1 carbs
Me, caravan....... I don't fink so!!
I do like me torque so this will be on my xmas list for Santa!!
Thnx for the info James
