4age whot is it out of .i was going to fit a zetec but it seems to sit high is 4age? lower .is the sump tin .i did mk1 escort with zetec fitted
sierra cvh sump .
well in the us the 4age came in toyota corollas and toyota mk1 mr2's
same in the uk...
Check out the cost of the bits you need before you buy the engine though as some parts can be a bit pricey but the 4Age only comes in 1600 guise.
try RAW Engineering.
Keith
Suffolk
here in the us the 4age is a very cheap motor somewhere in the range of 3-400 for a longblock running with good compression. theyre also very easy to modify i have a buddy who made a turbo exhuast manifold and did all the work himself to turbo his car for less than 1000 dollars.
