I am fitting GSXR 750 TBs and injectors on a zetec. After headwork and new 285 cams I am aiming for about 200bhp.
Does anyone know the flow rate of these injectors. They have a D on one side (?Denso) and some numbers on the other.
28, 731 and 3380.
600's are 220cc/min, and 1000's are 330cc/min if that helps
Ray
275cc I think
According to the sites I have had a look at on the web 275cc/min will not be big enough for 200bhp and 330cc/min is only just OK. Anyone got a better idea for scrapyard injectors that will fit and run about 350cc/min?
I agree with Stevebubs, I was told 270cc at 3 bar
I am running about 250 bhp on 48 carbs at the moment , has anyone tried GXSR 750 T/B in this power range .. If so what injectors did you use ,
please
Motor is a 2.3 n/a cosworth..
cheers
The 2000-2003 GSXR750 KEIHIN injectors should be 270cc at 3bar. Earlier ones had a lower flow rate (190cc at 3bar). Have a look at my TB conversion
pages for more info:
www.mymojo.co.uk
I'm running the 270cc injectors at 2.5bar on a 1.8 zetec with 130 cams, and the injectors are running at max 83% duty cycle. The same injectors
should be fine for a 2.0 running at 3bar, I would've thought...
Neil
Guys, with that in mind i would deduce that the 270cl are too small for my application, what would you suggest to get the flow rate upto 350 to support this extra demand. ?
Look at what the cossie turbo tuners are using for this sort of horsepower and fit a set of those...reasonably easily obtainable off ebay...?
Just get some standard cossy yellow injectors. Flow rate is about 310 i think but they easily support the 200+ standard power of the cossy. And a NA
should use less fuel per hp than a turbo anyway.
Liam
HiLiam, that was my inital thought, but i am running 11.8:1 comp. and i would hate to run the system at fully duty rate down the back straight on the
rev. limiter .( box of scrap)..
but i will try it on the rollers ..
cheers- Andrew
well im planning on the same install with GXSR750/zetec with standard injectors so hope mines ok ill let you know in a few weeks!!
if not my mega squirt has been set up for 13.4ohms injectors (750 ones) will i have a problem if i change them??
FWIW, I'm running the same setup but on Vectra GSi Injectors (Purple ones, High Impedence).
didn't try the original Gixxer ones - went straight to full size car injectors.
Originally posted by fully sideways
HiLiam, that was my inital thought, but i am running 11.8:1 comp. and i would hate to run the system at fully duty rate down the back straight on the rev. limiter .( box of scrap)..
cheers- Andrew![]()
Not so long as you change the for high impedence ones.
If you go for low impedence then you'll need a resistor pack to bring the impedence up.
Sorry Liam, I seem to hijacked this thread, the first application was a Zetec, but i am running a 2.3 holbay cosworth.. the power is estimated at 250 gee gees as we can not keep it from lighting the tyres on the rollers .... big tyrs & glue & 3 in the boot has been tried .. makes fun for days in the wet .
