Help - Ford gearboxes
Nitrogeno25 - 2/2/06 at 08:44 PM
Can anybody with a type 2 gearbox (from the 1600 escort) and a type 9 confirm if the starter motor pattern for the holes is the same?
Thank you very much.
theconrodkid - 2/2/06 at 10:47 PM
asuming escort is 3 bolt fixing then yes
Nitrogeno25 - 2/2/06 at 11:09 PM
First thank you very much!
So asuming a LRS707 starter fit a type 9 with a zetec it should work with a type 2 and a zetec too...
theconrodkid - 3/2/06 at 07:55 AM
should fit then,there have been clearance probs with starter hitting sump tho,only 1 way to find out
Nitrogeno25 - 8/3/06 at 07:51 PM
Well my gearbox (type 2) has 3 holes for mounting the starter, but the original starter has 2.
If anyone can confirm that the type9 has exactly the same pattern (for the starter) as the type 2 I would be very very very very grateful!!!!
theconrodkid - 8/3/06 at 08:01 PM
very early fords had 2 bolt fixing,i seem to remember 2 bolt starter will fit a 3 bolt gearbox
the reason they changed was the bolts kept coming loose,stick to 3 bolt
