Fuel resistant sealent
shortie - 16/2/06 at 10:19 AM
Does anyone know whether I can get fuel resistant sealant as I would like to run a bead of sealant round the pipe that connects from the filler cap to the neck of the tank as sometimes you get a very slight leak now and again.
ta,
Rich.
Avoneer - 16/2/06 at 10:32 AM
Sikaflex or equivalent - most polyurethanes are fine in my experience.
Glued my fuel sender on with the Everseal stuff and no problems.
Pat...
Kissy - 16/2/06 at 10:47 AM
Cannot remember the grade you require (IIRC it begins with PRC... something like 1121a, but it was 15 years ago) but these people do a 2-pack compound I used to use on aircraft fuel tanks, smells liek s*** and sticks like it too! Doesn't degrade - be aware it is a mega-adhesive, it is a b****** to get off.
Stag Polymers & Sealants Limited
Tavistock Road, West Drayton, Middlesex, UB7 7RA.
Telephone: 01895 445511
Fax: 01895 449199
DarrenW - 16/2/06 at 10:48 AM
If you are not sure about a particular sealant - run a length out, let it cure and leave it in some petrol for a while. You will soon find out if it gets eaten up or breaks down.
You shouldnt have too many problem with filler pipe if it is a close fit to the tank inlet and you use a good quality clamp nice and tight. Mine hasnt leaked.
shortie - 16/2/06 at 01:03 PM
The pipe is the corregated type from MAC1, I have two clamps on it and it still leaks very slightly when you fill the tank, the reason you cannot get a perfect seal is because the tubing has wire running through it so it can't clamp perfectly to the filler neck.
Rich.
DarrenW - 16/2/06 at 01:52 PM
Ive got the same one and havent noticed a leak - maybe i need to takle a closer look. The pipe was very tight to squeeze over the tank inlet, i wonder if that made a difference.
shortie - 16/2/06 at 02:27 PM
TBH you wouldn't notice it normally but after filling the tank then run your hand down the sidefront of the tank (from underneath) and you may find a small amount of fuel or a slight sticky residue left over from when you last filled it.
I am also aware of another builder where it was noticed at SVA but he passed it off as where he'd been cleaning stuff.
Rich.
JB - 16/2/06 at 06:54 PM
Loctite 518 is a great all round purpose sealant that I have found oil and fuel resistant. It is quite expensive but does not go of in the tube so will last years.
John
