to run a pinto on bike carbs using the dizzy? iv heard of it being done but am a little dubious
Dunno why not, is the dizzy gonna get in the way of a set of carbs ?
what is a dizzy?
shouldn't be a problem, obviousely you'll need a dizzy cap with right angled connections, also some bike carbs are designed to be fitted at
an angle(the air filter fits in a recess inthe fuel tank), using these should give you a bit of extra clearance.
Ray
dizzy = distributor
I think you mean the problems due to lack of a constant vacume to run the advance/retard mech.
Run a line to each runner feed them all in to a small chamber to act as a damper then feed the dizzy from that.
wouldnt vacumless distributor sort that problem? i was thinking of the fuelling would i need some sort of ecu to control it?
Hi just fit them and go . Its better to have megajolt but it can be done with original dizzy . have a look in my photo archives under zx9r
Jacko
I nicked the idea from Paulf he used a small spent co2 bulb.
I nicked the idea from Paulf he used a small spent co2 bulb.![]()
Originally posted by 907
I'm running twin Delortos and I also have a vacuum gauge. The gauge was into no4
and the advance pipe into no1, but the gauge flickered so I joined 1 to4 and joined
into that. It still flickers a bit.
with a vac gauge you need a restricter followed by a volume --- for the volume try the fuel trap between the throttlerbody and the ECU from a 90s Rover. For the restricter just make an adjustable clamp for the rubber hose.
what is a dizzy?
Or put a .6mm mig nozzle in the line , I found one is a push fit into the 4mm vac tubing I am using . I used a cut down Co2 bulb as a fuel trap and
soldered a top on it with an inlet and out let pipe made from brake pipe as i couldnt find a suitable fuel trap .It is a good idea to have a fuel trap
in line anyway as i found my map sensor had got fuel in it after a few miles with out a trap fitted.
Paul.
I have a few spare if anyone wants one ,as i have a co2 powered air pistol that uses the bulbs and they are disposable when empty.Willpost a picture
later of how mine is fitted.
Paul.
HI Big Wasa what is a co2 bulb please
Jacko
