Does anyone happen to know the size of the camshaft pulleys of the Ford Zetec or Toyota 4AGE?
It is for twincam Mini...
Thanks in advance
120mm dia x 30mm thick. Hole for cam is 11mm but slight taper. 40 'teeth'
Thanks! This data is for the Zetec?
Sorry I should have said zetec.
Hmmm, that's sadly too large. I need something with a diametre of 90mm or smaller.
Any suggestions?
Richard
Unlikely to be a cam pulley, then. If you used a 90mm cam pulley the crankshaft pulley would be 45mm, right? That's smaller than most cranks.
Best bet for a toothed belt pulley is an industrial bearing and drive supplier. They're available in all diameters and tooth shapes. Search for
"synchronous drive" or HTD belts.
Eddy
[Edited on 1/3/06 by eddymcclements]
@eddymcclements:
Well, I know that Ford Pinto cog wheels fit and there are other engine cam pulleys that fit. So it's not impossible.
But what's the dimension of your 4AGE cam pulleys?
I will anyway research your tip on HTD belts.
Richard
