iv been reading in the archives that a facet pump and pressure regulator will not be suitable for bike carbs, is this true? if so what pump should i
use i have a 2.1 pinto running 36mm mikuni carbs will a normal bike pump be able to pump the distance from tank to bay?
cheers
james
Yes no problem....I was in your position a month ago but anything 600cc + will churn it out no problem.....Oli.
ditto, normal bike pump.
Originally posted by auzziejim
iv been reading in the archives that a facet pump and pressure regulator will not be suitable for bike carbs, is this true? if so what pump should i use i have a 2.1 pinto running 36mm mikuni carbs will a normal bike pump be able to pump the distance from tank to bay?
cheers
james
fortunatly i didnt purchase a facet pump and reg before i heard that it wouldnt be suitable for bike carbs.
i have spyed a zx9 pump on ebay ending in 2 hours still at 99p no bids, it will be mine
dont tell everyone!
