Using a rw drive donor for an mid engen car can i do next if i bypass the shaft and conect gear box and rear diff.And how will i cange gears any
pictures will help
I've seen it doen once before. It was the longest powertrain I've ever seen in my life. You have a gearbox output shaft and a diff input
shaft to accomodate. A proper transaxle incorporates all of these together.
What about an Audi 80 gearbox - this is in line and much shorter than you propose.
I have one cheep idea for mid engine , use the rear axel and diff from OLD vw Beetle and Honda engine , lot of honda engines are left so it will ride
in right direction.... ....
the other method is to modify Rorty IRS plans and put comlete engine and Front wheel drive from a donor....
modify Rorty IRS WHERE CAN I FIND THAT
U can search the forum or give me a e-mail and I'll send it to you...
locoo@net.hr
