radiator
timex - 16/3/06 at 04:10 PM
I am building a velocity XT with a 2LT zetec witch radiator will I need
NS Dev - 16/3/06 at 04:13 PM
does it already have brackets there for the radiator? If so, best ask Luego
if not use a VW polo 1.0 one, £45 from GSF
JAG - 16/3/06 at 04:13 PM
Favourite is the VW polo radiator from a 1989'ish 1 Litre model.
Beware which rad' you get as the matrix size varies from model to model. I have the 380mm wide matrix and it just fits into a Stuart Taylor nose cone.
My supplier originally sent the 430mm matrix version and that doesn't fit.
NS Dev - 16/3/06 at 04:16 PM
GSF part number 17321B
£43.50
muzchap - 16/3/06 at 04:17 PM
I'm building one and I got a Mk2 escort one - that has been re-cored.
It's from Boston Rads - they supply Luego on an exchange basis.
Prolly easiest to plumb in as well
Pics in my archive..
timex - 17/3/06 at 03:02 PM
Thanks I will give luego ring.
Dave Bailey - 17/3/06 at 09:06 PM
Luego best idea but if not I bought one from a guy that advertises on ebay for 38.00. With some home made ally brackets it fits a treat into a velocity with a little bit of material removed from the existing mounts
Mix - 18/3/06 at 08:51 AM
Nissan Micra rad is another option.....pics in the archive.
Mick
