hi all
i spent 2day removing my crossflow because both crank seals needed replacing. I dont know what cam is fitted in my engine but i know it isnt standard
. So 2day while i had the rear crank seal plate off i had a look at the end of the cam hoping to see a stamped ident. i can clearly see the letters
" kc ..." but the orginal numbers appear to have stamped over so i can't read any of them. The reason i want to indentifiy it is so
that i can set my valve clearance correctly. what would you guys surgest i now set the clearances 2. Also,ive never had more than 35 psi oil pressure
even after uprating pump. 2day i noticed that the oil pick up pipe is not at all a tight fit in to block so im hoping that could be the cause of that
problem
cheers
craig
kc .... and the sunshine band?
