wrapping manifolds
westf27 - 24/3/06 at 01:20 PM
going to wrap the manifold pipes and wondered how?Should I butt the turns or overlap them.Also got stainless ties,use these or is there another way to secure the start and finish
Mr G - 24/3/06 at 01:34 PM
You'll want to soak it first, wire, metal ties, jubilee clips will all be fine.
Just a normal even overlap all the way down and jobs a good-un
G
[Edited on 24/3/06 by Mr G]
Nosey - 24/3/06 at 01:43 PM
Read on our instructions that you are not meant to soak it, just spray water on the wrap to soften it up. Not sure if its different for different makes.
We used the ties at the head where they look tidy, and stainless lacing wire anywhere else it was needed.
Mr G - 24/3/06 at 01:51 PM
Depends if you want a nice tight fit or not, soaking then fitting will produce and excellent shrink fit.
If you want just pliability and reduced dust emission then a spash and dash is fine
Don't you just love locostbuilders - clear as mud
rusty - 24/3/06 at 03:42 PM
I heard that wraping the manifold make sthe silencer get very hot and melt the side of the car is this true of just lies.
westf27 - 24/3/06 at 03:56 PM
dunno let you know
bimbleuk - 26/3/06 at 06:42 AM
Cast manifolds can crack when wrapped dut to the heat retained by the wrap. SS or MS manifolds are more likely to crack at any welds. Moisture can be trapped in the wrap which can accelerate corrosion. More dependant on where the car is stored.
Yep the wrap can make the exhaust gasses hotter entering the cat/silencer which agin could shorten the life of them a little. One positive is that the higher exhaust gas velocity could possibly help with cylinder scavenging.
Personally i would always consider ceramic coating as a first choice but of course the cost is higher.
[Edited on 26/3/06 by bimbleuk]
