Leaking Crossflow Fuel Pump
rayroni - 28/3/06 at 02:09 PM
Have got an old glass bowl type fuel pump and fuel is leaking from where the bowl meets the fuel pump body, tried tighting it but looks like the O' ring type seal has had it.
Suspect I am going to struggle to find a new seal - can anyone suggest where I can get one or any others ideas for a cure?
02GF74 - 28/3/06 at 02:24 PM
Ford, Burton power???
your local plumbing o-ring shop?
Or these: http://www.busakshamban.com/ADMIN/ASSETS/files/o_ring_gb.pdf
of here: http://cgi.ebay.co.uk/MIXED-METRIC-O-RINGS-4mm-40mm-50-Pack_W0QQitemZ8048970793QQcategoryZ30928QQrdZ1QQcmdZViewItem
or make your own seal from gasket material?
[Edited on 28/3/06 by 02GF74]
britishtrident - 28/3/06 at 04:27 PM
It should be a flat rubber gasket not an O ring.
The pump must date from pre 1971 variations on the same AC pump were fitted o a lot of cars inclunding most of the Rootes and Troumph ranges
http://cgi.ebay.co.uk/LANDROVER-FUEL-PUMP-REPAIR-KIT_W0QQitemZ4618003752QQcategoryZ31348QQcmdZViewItem
http://cgi.ebay.co.uk/TRIUMPH-VITESSE-2LTR-MK2-FUEL-PUMP-REPAIR-KIT_W0QQitemZ4624208472QQcategoryZ27383QQcmdZViewItem
http://cgi.ebay.co.uk/SUNBEAM-ALPINE-RAPIER-H120-FUEL-PUMP-REPAIR-KIT_W0QQitemZ4625377019QQcategoryZ36090QQrdZ1QQcmdZViewItem
