ive just got a x-flow engine,the engine number looks like UE 27900
and the number cast in the block is :-
681-F -6015-HA,can anyone help on age and engine size please
easiest way to tell the size is fingers between bottom of stat housing and water pump,2 is 11/1300.3 is 1600
if only life was that simple,thanks,what about age ??
March 1968 according to Burtons !!
Jason
wow 1968 blimey
AS stated, it's a 68 block. Get yourself a free Burtons catalogue, a page in there lists all the codes and dates.
020 8554 2281
www.burtonpower.com
You have an early crossflow, really you want a 711M 6015 BA engine, 1970 onwards it's a better stronger block than the one you have.
Cheers John
thanks John
i do have two 711 engines,one is siezed and the other has been outside for about 20 years so both need a rebuild,the 68 engine was a cheeper option
than a full rebuild after all my car was meant to be a LOCOST ?? thanks for ll your help
the last two letters are engine capacity;
from memory AA = 1300
BA = 1600
or soemthing like that
although the 711 is the more desirable, don't worry about not having one of those; it should be fine.
