Hi folks
Question, I have the dark grey injector type A in the pic below. Does any one know if the one marked type B would be OK to use as it seems to fit.
If any one has a picture of the later green type injectors from the 4age that would really help me out as I'm trying to find some for my engine
(with a higher resistance and larger flow rates than the one I've already got).
[img][/img]
i got some green type injectors, not using em so if you want them make me an offer.
rob
I have a set of SUPRA injectors (4 of em - yes I know there's normally 6) :-)
They will fit and are almost brand new.
Make me an offer
If those are the Supra black injectors they're 440cc/min which is pretty massive.
The pink ones are low impedance as well and will fit (with a change of connectors). 215cc/min IIRC
Are the greens you're thinking of the 250cc small port ones? They may be low impedance as well.
From the list I have, there were / are only 3 pink injectors and of these only one had R (ohm) of 13.8, which mine do and therefore these have a flow
rate of 315 cc/min. So bingo, I think I already have the ones I need (but I may need a back up if I'm wrong) so I'll get in touch soon with
you Rob (any chance you could post a photo of them?). Thanks for your help though.
Any one know how easy it is to measure the flow rate of injectors?
Rich
The Supra injectors I have are Green
They are the 315c version...
Go here:
http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Injectors.html
Rich
