Clutch Pedal Leverage
Dusty - 15/4/06 at 04:53 PM
Just changed to floor mounted pedal box with cable operated clutch, type 9 box. Current clutch pedal leverage ratio is 3:1 and it's far too heavy.
Suggestions please for a more sensible ratio.
DIY Si - 15/4/06 at 04:57 PM
4:1, 5:1...... Depends upon what you consider too heavy really. Try 4:1 then just keep going up, if poss, to something that feels right for you.
indykid - 15/4/06 at 05:03 PM
new cable?
the indy has about 3:1 clutch ratio, and i'd never have deemed mine 'heavy'
heavier than a tin top, but then you'd expect that imho.
tom
bimbleuk - 15/4/06 at 07:15 PM
The clutch type will make a difference too. My setup has a type 9 box and a Toyota clutch. The pedal ratio is 4:1.
planetester - 15/4/06 at 08:37 PM
Remember the higher the ratio , the more pedal travel you need for the same release arm movement
Dusty - 15/4/06 at 08:47 PM
I would like 7/1 but can't extend the footwell to the radiator to get enough range.
auzziejim - 15/4/06 at 08:58 PM
or your leg
Dusty - 15/4/06 at 09:14 PM
Pedal is 150mm long so 35mm arm length will give a ratio of 4.3:1, 30% decrease in cable pulled and 30% less effort. (I think. Not brilliant at maths.)
