received prop yesterday struggling to get it in without removing engine/gearbox or diff i decided to split the rear u.j. and remove the rear flange, prop then fitted into box and into turret re fitted rear flange and u.j and bolted to diff about twenty minutes to fit happy now no need to move engine hope this helps anybody else about to tackle prop fitting
You did well to get the UJ apart without dropping a load of needle rollers!
John
one advantage of working on land rover shite for seven years was the number of prop u'j,s i've changed
