Hello, its been a while since I've posted on here, got back to my custom fireblade powered build today, its been sitting for a while.
Anyway, when I turn the ignition on the fuel pump starts, but doesn't stop, there's plenty of fuel, no leaks...etc. Engine will start, but
doesn't run very smoothly.
Also the water temperature seems to be climbing much slower then it used to, the reading it gives can't be right as the engine will be too hot to
touch, and the guage still shows cold.
Any ideas? cheers,
Mark
I would say the water problem sounds like it could be a stuck thermostat.
not sure about the fuel pump, I seem to remember mine pumps alot sometimes, maybe the carbs need balancing if it's running a bit lumpy.
Rich.
Hi
Not sure if this wil help but if you are running a carbed blade, we had the same fuel problem and found it in our case to be caused by the carbs
allowing fuel to escape through the breather pipe due to them not closing properly and pressurisingand so the fuel pump kept on pumping. You may not
notice the fuel escaping if you have connected the breather to a filter / airbox as it was origionally connected on the bike. If this is the case, all
we had to do was simply drain the float bowls using the drain screws on the bottom of each to get the rubbish out. After doing this they seemed to
pressurise and the pump then shut off.
HTH
Ed
[Edited on 27/7/06 by esn163]
a friend of mine used to have a similar problem on his 893 blade bike after it had been sitting around for a while. He said it turned out to be old
fuel crystlising in the carbs. He had to strip the carbs down clean them out and re-balance them, after that it ran fine. Just fort id tell you this
as a possibility!
Hasn't been standing too long, right i've drained the carbs, and now remembered the next little glitch. The ignition won't turn on when
off for about half an hour, but go to it the next day and it works fine? very strange.
Anyway when it lets me turn it on again i'll see if draining has done the trick.
