clutch release arm travel?
craigbunnell - 1/8/06 at 09:32 PM
Hi,
Ive assembled clutch release bearing and arm, flywheel, clutch and then put zetec and type 9 on mountings. Now come to attach clutch cable and noticed the release arm as only 1 inch of travel and is not springy it just floats back and forwards (Essentially no clutch), what have i done wrong? do i have to drop the gearbox?
Craig
Schrodinger - 2/8/06 at 08:55 AM
Which clutch release bearing have you used you will need one for a Transit IIRC not the standard Zetec or Pinto ones as they do not have a long enough nose.
Danozeman - 2/8/06 at 08:55 AM
What clutch, box and release brg do u have??
I had this problem and my bell housing was wrong.
see here
roadboy - 3/8/06 at 11:45 AM
Sounds like the release bearing is too short. A cheap fix to move it up is to pull the fulcrum pin out, drill & tap the hole, fit a bolt with a nut & washers to move the fulcrum nearer the clutch, which moves the opposite end toward the rear of the box. A little experimentation with the adjustment & there you go. The expensive way is to buy an extended bearing carrier from Westfield.
HTH
Ian
rocket - 6/8/06 at 07:18 AM
I haven't got round to fitting my engine yet but will be useing 2l zetec and type 9.
I have fitted the 1.8 flywheel but used the cvh clutch and pressure plate ( it came with the donor cvh1.8 glx sierra)
All seems well and I'm using the original starter etc.
Anyone else done this does It work?
Rgds
Roger
