ford type 9 and right angled speedo drive
2litre-e - 5/8/06 at 08:51 AM
hi all, not got a locust but a highly modded spitfire and could do with some help.clearance with my box is minimal so if i use a normal cable it will bend far too much and break quickly, a right angled drive is 100 quid from burton but i've been told that the transit uses one, anyone know if this is correct and how early do i have to go to find one that is suitable. burton said there's were 4cm long which may ne too long for me anyway i'll have to get the hammer out. thanks.
[Edited on 5/8/06 by 2litre-e]
Danozeman - 5/8/06 at 09:04 AM
try speedy cables
There right angle drive is 40 quid and theyl make u up any length of cable you want for not much more money.
Your car sounds interesting. What are u doing to it??
2litre-e - 5/8/06 at 05:44 PM
thanks for that i'll ring them on monday. nearly finished just waiting for my rear hubs to be machined. mods as follows,
rebuilt c20xe on 4 tapered throttle bodies,
kronenburg engine management ecu
ford type 9 gearbox,
subaru impreza r160 rear lsdiff,
machining gt6 rotoflex hubs to accept mgf rear bearings, having custom driveshafts made to accept inner subaru and out mgf cv joints.there's a whole thread on it in the club triumph forum, its in the spitfire section and has a heading ' here we go'. cheers
Chippy - 5/8/06 at 09:50 PM
Thought they put the Merlin 12 cylinder in the Spitfire, shame to change that. ATB Ray.
Danozeman - 5/8/06 at 10:28 PM
sounds interesting. ill have to have a look up on the other forum..
2litre-e - 6/8/06 at 12:09 AM
took it out because it was rubbing on my tyres when i lowered the suspension.
mad4x4 - 6/8/06 at 10:00 AM
Why not change it out for an electronic pickup.
2litre-e - 6/8/06 at 02:46 PM
could do but they tend to be expensive , if the right angle drive is to long then i'll have to do it.
