GSX-R 1100??
MattCraneCustoms - 19/8/06 at 05:56 PM
How possible is it to fit such an engine? I've not entertained the idea of a BEC but when such an engine becomes available, you have to. How would I go about the gearbox? Surely converting a bike into a RWD car is gonna be a serious pain in the a**?? And also I've read on here about dry sumping this engine. Would this be necessary? if so what sort of cost is that gonna amount to?
Regards,
Matt Crane
graememk - 19/8/06 at 05:58 PM
i think you need to have a look through hell fires build web site so you can get your head around using a bike engine its not as hard as you might think
DIY Si - 19/8/06 at 06:19 PM
It's actually fairly easy. You need a sprocket converter to allow a prop to run from the output on the bike's gearbox to the rear diff. Otherwise it's mainly as with a car engine, ie exhaust out the side, wiring loom in with ecu....etc etc. Also, if the engine comes with clocks you can use them too.
phelpsa - 19/8/06 at 07:34 PM
Are you talking about the oil/air or water cooled gixer engine?
cloudy - 19/8/06 at 10:36 PM
even easier if engine is at back
phelpsa - 19/8/06 at 10:59 PM
Originally posted by CaLviNx
Basically a bike engine is a bike engine if its the older motor your not going to have to worry about plumbing in a raditaor as the older ones are air/oil cooled.
Although you do have the problem of finding a HUGE oil cooler My 40 row mocal jobby should do the job
MattCraneCustoms - 20/8/06 at 06:25 AM
Thanks for all the reponses guys thats given me a lot more confidence than I had before. One last thing though, how difficult is it regarding clutch / gear shifting?
NS Dev - 20/8/06 at 09:57 AM
yep, watch oil temps if goign air oil cooled
not sure at all for long term road use, certainly lots of oil cooling needed.
