Zetec 1.8 105 or 130?
MattWebster - 2/10/06 at 11:48 AM
Hi All,
Does anyone know which 1.8 Zetec (Silver Top) engine spec the following cyclinder head number refers to? Is it the 105/115bhp or the 130bhp head? I'm lead to believe it's the 130 but I'm not sure.
958M 6090BC
Danozeman - 2/10/06 at 12:31 PM
Do u know what the engines out of??
Theres not many standard 130 1.8's about. IIRC they were in the escort rs..
MattWebster - 2/10/06 at 01:19 PM
Not sure if it's been in anything. It's a new engine done zero miles apparently, all ports are sealed. The previous owner bought it "Unused from a kit car garage " All I know is the Cylinder Head number 958M 6090BC.
procomp - 2/10/06 at 02:17 PM
Hi the only real way to know what psi engine you have is to check the cams by looking at thier casting rings between the cam lobes.
cheers matt
scotty g - 2/10/06 at 07:58 PM
The number on mine starts with RY then some numbers then ends with RKA, not the same as suggested above so what does this mean??????????????
david walker - 2/10/06 at 08:29 PM
Stuart G's engine codes specify the the engine type. You hare quoting the engine serial number.
A Ford engine number starting with RY means it was manufactured in February 1994
mad4x4 - 2/10/06 at 08:37 PM
If you send the engine number to for they will tell you not only the age but if it is a 115 or a 130
MattWebster - 4/10/06 at 03:28 PM
Yip it's the one off ebay. The 130 would be a nice to have and as you say it's not hard to convert with a set of cams. As it's a direct replacent for my current engine so having a Zero miler is a plus. Hope to have it in this weekend : )
