Zetec Inlet Manifold
TangoMan - 6/10/06 at 06:57 PM
As winter approaches (I know cos it's bloody cold!!!) I am looking to start my upgrade.
I know that exhaust manifold flanges are avaialble on eBay but have not seen any inlet flanges.
I seem to remember someone on here having some made.
Does anyone know where I can source a flange, in either ally or stainless.
Thanks for any info.
britishtrident - 6/10/06 at 07:29 PM
CVH exhaust manifold can be fitted to a Zetec with a bit of dring and tapping --- some say one tiny bit of alloy welding is also advised.
There is a web page somewhere on the web on how to do it.
ex Westfield CVH manifolds have be known to be found on Ebay
coozer - 6/10/06 at 07:47 PM
Cut one out round the gasket. Dead easy with a pillar drill, file and jigsaw
big_wasa - 6/10/06 at 08:23 PM
You could try This place or why not ask Bogg Bros They have these cut from alloy to make there bike manifolds. Or Altiss.
Can I ask what your plans for induction are ?
As Trident says a cvh manifold has the same port spacings as the zetec but diferant stud spacings and it can be used to run a zetec withe a single carb for not a lot of money.
I have been playing with this conversion inbetween the locost and have a spare modified manifold minus adapter plate that is FREE to anyone on here that will cover the postage( I did my own as it wasnt up to my standard)
[Edited on 6/10/06 by big_wasa]
big_wasa - 6/10/06 at 08:24 PM
I am pleased so here is a photo of the project engine
Peteff - 7/10/06 at 08:48 AM
I've been looking at a 1.8 XR2i engine I have and the inlet manifold looks like it could be cut and shut to mount bike carbs or throttle bodies.
[Edited on 7/10/06 by Peteff]
TangoMan - 8/10/06 at 04:34 PM
Do you have any photos Pete.
If it looks like it will do the job I can start to trawl eBay.
thanks.
Mansfield - 8/10/06 at 08:24 PM
All depends what your induction plans are.
I have a carb manifold for a CVH and I don't have the ability (ally welding) to modify that to take bike carbs/throttle boddies. If I did have I think I would build my own from scratch, there would be a lot of modifaction required to make this work on more than one carb.
I also have an inlet manifold for twin webbers, this would be a far better start point to take bike carbs/throttle boddies if you can ally weld. They go for reasonable money on ebay too.
I can't comment on the CVH EFI manifold as I don't have one.
I have a 1.6 CVH engine, so I am not troubled by modding the stud spacings but if you want any dimensions of what I have then please ask.
