having put twin 40 dellortos on to manta 1.8 ohc have now found alternator is in way .answers on a postcard please?
still scratching head ,anyone know which car has smallest alternator???
daihatsu charade 1.3 16v or similar
I've got a suzuki swift alternator on the other side to normal on my Vauxhall XE engine. Nice and small and i got it free too
is it poss to swap sides on the manta ohc?
turn the alt. around 180 degrees.
But that makes it spin the wrong way, granted it shouldn't affect charging, but it won't cool very well.
as others have said, it will run in the opposite direction.
I am sure I have seen somewhere that it won't work but from what I canremember bbout rotating electrical machines, I cannot see why not.
that looks like a lucas 1a27 or similar - I am pretty sure the brushes and commutator are symmetrical so I see no issues there.
About the fan; should be possible to flip ir round but would need spacers for the pulley so the spinlde may be too short for that.
I am curious if you have you had it running?
--------- slight off topic - has anyone used a bike alternator on a car? I don't know much about them but think they are driven by a gear - so
it should be possible to fit a pulley onto one?
it will run just as well backwards as forwards.
No brush wear issues (checked with alt. referb. company)
With regards to cooling, the most demanding load on the car is the headlights, & I don't intend to do a lot of night driving
If it was flipped around it wouldn't cool at all as the fins would be facing away from the cooling vents
(ofcourse you're right)
