As the title, which is the better option, the std oil filled coil, or the later type of dry coil?
Seeing as no one else seemed to know.... I finally found the answer to my own question.
The dry type is better as you dont run the risk of it boiling over if it gets hot and it also produces a fatter spark.
Now I know
