motorcraft carb
myeates - 2/11/06 at 03:52 PM
hi does anyone know where i can get a gasket set from for the standard carb off a ford motorcraft carb from a 1.3 x-flow 1972 mk1 escort
GazzaP - 2/11/06 at 04:10 PM
Try burton power usually quite good on spares.
Gary
thunderace - 2/11/06 at 04:37 PM
is it for a twin chock weber and is it the one with 4 bolt holes in it and its a thick plastic type one with paper gaskets ether side as i have a spare one.
can send you pics
myeates - 3/11/06 at 09:16 AM
hi no its the single motorcraft with two bolt holes
thanks anyway
thunderace - 3/11/06 at 02:01 PM
is it a paper one you need??
myeates - 3/11/06 at 04:04 PM
its the whole set as we are going to strip it down and rebuild as been sat around for a while
