These look like crossflow engines, maybe similar to the ones in the Festiva. DIS, clutch, flywheel, carb....seems like a good deal if you're
looking for a tiny engine, esp if it is related to the crossflow.
http://cgi.ebay.com/ebaymotors/Complete-Ford-1-0L-1-1L-Industrial-Engines-VSG-411_W0QQcmdZViewItemQQcategoryZ33615QQihZ012QQitemZ220044737136QQtcZphot
o
called a valencia here in euroland,best known for their ability to smoke and rattle and generally be the worst engine ford ever produced.
Rattle thats an understatement
Over 100kgs for a 1 litre engine
Simon
Originally posted by theconrodkid
called a valencia here in euroland,best known for their ability to smoke and rattle and generally be the worst engine ford ever produced.![]()
I thought it was only the Pinto engines that rattled and smoked and were the worst engines ever produced. Do you mean to tell me that Ford produced more engines with the same characteristics?........![]()
Phil
Don't forget the leaky core plugs.
I thought the 2litre V4 was the worst engine Ford produced?
I had a V4 tranny pickup for two years and it never missed a beat and my Pinto doesn't rattle now it has a new cam. CVH only rattle when they are neglected in the oil change department bu the Valencia or HCS is renowned for it's metallic sound qualities.
Nowt wrong with a good oh pinto
We used to get a G reg 1.3 Escort with the HCS motor in once a year for MOT & service. It got no other attention unless it broke down. When the
rot finally killed it a couple of years ago it had 223,000 on the clock (which had stopped due to the diff bearings going & eating the plastic
drive gear). The motor was never apart in the time I knew the car.
But it did rattle a fair bit
