whats the going rate for the throttle bodies? I want to use them on a 2L blacktop, unless any one has another suggestion.
ok for a standard engine but if you want to tune it, 600s will probably become restrictive
[Edited on 10/12/06 by stevebubs]
*Yawn Calviwhatsit starts being petulant. Should really rise above it but can't be @rsed*
Can I ask why or how you come to your conclusion above ?
Also can I ask if you have read the book on engine management by *Dave Walker* ?
I would have thought the venturi size was more important than what bike it came off.
Interestingly on my 3.5L rover V8, 38mm chokes off a Honda CBR600 are just fine, except the manifolds are £600 a pair..
Also the internal dimension of 46mm Ally Scaffold pole is almost perfect for 38mm Venturi's if you are making your own manifold.
Remember that a Car Carb Venturi will flow less that a Bike Throttle body of the same diameter. ie there are no webs and jet protusions in the
throttle body, which lessen the through put of the car carb in relative terms.
Long term I am going Megasquirt (already built) and 8 x throttle bodies on a home made manifold (my mosy difficult bit to do)
All good fun eh?
calm down lads,
Basically i was going to use the engine in standard form until i got thru the sva then maybe then start messing around with fast road cams and the
like.
With the bike throttle bodies there seems to be such a large selection, i was just wondering if there is a prefered one.
[snip]
All good fun eh?
Originally posted by prelude1980
calm down lads,
Basically i was going to use the engine in standard form until i got thru the sva then maybe then start messing around with fast road cams and the like.
So...are you going to actually contribute anything useful to this thread?
Abrasive, if a question a simple as that makes you, anyone even the pope squirm, then it might be reaching the spot a little closer than the initial poster would like, you obviously took a totally simple question and wound your own colon right up....... to such a point you could make pretty patterns with your skat......![]()
(EDIT1)
Oh as for mastering the English language I'm NO Fecking Englishman, and usually i have NO need to hide anything behind a nuance, if i meant to say something i will namely from your reply i think your a dick...
(EDIT2)
Also instead of atcually answering a perfectly valid question YOU saw the need to go on a full attack, the symptoms of some-one with a guilt complex.....
[Edited on 10/12/06 by CaLviNx]
Roll on devolution.
[Edited on 11/12/06 by gazza285]
Just to be pedantic (and factually correct), throttle bodies don't have a venturi.......
And the correct answer to the original question was?
GSXR 600 throttle bodies will be "ok for a standard engine but if you want to tune it, 600s will probably become restrictive".
Also can I ask if you have read the book How to Win Friends and Influence People by *Dale Carnegie*?
Gazza your responses never cease to amuse!!!
As for throttle body bores.....who knows?
Dave Walker, writer of "said book" ran a Vauxhall XE16v engine up at QED some years ago with numerous different sets of bodies on it, and
45mm vs 48mm showed little difference, other than some reduction of lowdown torque with the 48's.
my own experience shows similar, I have 45mm jenvey sf's on the locost, and had 48mm jenvey twins on my grasser.
48's were prob a tad big, that's with 200hp.
I'd say around 40mm ballpark will be what you are looking for on a 2ltr std engine that may be mildly tuned in the future.
bit bigger than that if you are doing more tuning and nudging towards 200hp
and he's a nice chap but to get back to the topic, would a set of 600 throttle bodies work on a 1.8 zetec, not planning anything like cam changes
etc ? Whichever bike they came off they would probably be made by similar suppliers as with brakes, they don't make all their own parts.
[Edited on 11/12/06 by Peteff]
That's what I'm using on a 1700 crossflow (600s), so I would say they would be ideal on an 1800.
I´m in to!
CaLviNx AK[MY Car MY Way]
YOU are going way to fast slow down a bit or you will be fined for speeding in the pitlane
No i mean even if he (or she??) was a dick who cares? we are here to help each other right? Looks some times that you are here for different reasons
one of them COULD be to show what you know...
and just let that be a sign of some complex...
Did you read the book "How to behave to not become ignored?" by * Locost Builders & Co *
you know i´m not serious you know?
BUT YOU DO GET THE POINT DONT YA??
Tks
[Edited on 11/12/06 by tks]
McGlashan
Watch a nice video clip and breathe deeply.
Just read this topic and laughed my nuts off!!
Cheers guys!!
Calling someone a dick is quite friendly really.
PPS.I have some GSXR 750 TB's to go on my 1600 4age,does that mean i'm wrong or just a Big Dick?
<Team America> "See, there are three kinds of people: Dicks, Pussies and Assholes.
Pussies think everyone can get along and dicks just wanna fu*k all the time without thinking it through.
But then you got your assholes, and all the assholes want is to poo all over everything.
So pussies may get mad at dicks once in a while because pussies get fu*ked by dicks, but dicks also fu*k assholes.
And if they didn’t fu*k the assholes, you know what you’d get? You’d get your dick and your pussy all covered in shit." </Team America>
Iain
[Edited on 13/12/06 by IainB]
EDIT:
Why is it the 1st Sh*t has been censored but the one at the end hasnt?!
