i currently have a 2.0l dohc sierra engine, but the size issue is annoying me as the chassis is finished, therefore, iw as wondering which engines fit
in the book chassis without any modification to it or the gearbox, is a crossflow ok?
Cheers, theo
in what way is that annoying?
2 ltrs seems fine to me.
sorry, by size i mean engine dimensions rather than capacity, my mistake!
sorry, theo
Originally posted by theohighland
which engines fit in the book chassis without any modification to it or the gearbox, is a crossflow ok?
Cheers, theo
IIRC only the X-flow fits the book exactly mostly due to engine height. You need at least an extra inch to get any Pinto into the locost unless you
intend to drag your sump along the road! The only real problems are sorting the nosecone , bonnet and scuttle height, I am dealing with this now
myself! Some people just ad another length of 25 box to the top rail, that seems to work but is I think a bit inelegant though it looks fine if you
clad the thing with the side panels. I am presently working with a caterham pattern nose and this is more difficult as it is curved along the edge
that sits on the top rail so I may try and find another that is taller or at least has a straight edge !
I am also using webbers onmy Pinto to save having a hole in the top of the bonnet and a Robin Hood pattern exhaust that exits low rather than over the
top of the chassis rails though this does cause other issues maily with the cross brace which is coming out and will be refitted the other way around,
High at the scuttle and low at the nose.
I hope this helps, don't give up on the Pinto yet!
Caber
surprised know body has said this b4,
just fit a bike engine and new prop shaft,
less weight, great sound track,easy to convert,
job done,
so if i was to use a bike engine, where can i find out how to do it? ive searched the archives for posts on it but cant find anything useful as yet?
